1 - 6 of 6 Posts
The furnace installed inside a closet is being replaced. The platform supports the gas furnace and provides a return air vent prior to he filter. The original plywood platform had drywall on top of it, and the furnace on top of the drywall.
I don't like the drywall for the platform, however I am looking for an alternative non-combustible material.
· Hvac Pro
You may want to stay with drywall and put some galvanized tin/sheetmetal on top of it if you want it to be more durable. In my experience the gas inspectors have very little imagination and unless you have documentation to prove the other material meets the gas code etc they may shut you down. Not worth the huge hassle to deal with them and that IMO. You can get galvanized tin at HDepot or any HVAC shop.
Discussion Starter · #6 ·
Thanks for the response. The installation manual only indicates non-combustible material. That's likely the solution I will go back to. I believe that Hardibacker will still transfer the heat, and I wanted to avoid the silica dust if left uncovered.
1 - 6 of 6 Posts
