I have a doorway with metal corner bead. I want to close off the doorway with drywall. Do I have to remove the corner bead before adding the wall and drywall to block off the door in order to get a smooth finish?
If you do not want a hump the shape of the door in the middle of the wall then yes it's got to go.
I just tap it with a hammer to break up the old mud and pry it off.
Reactions: Willie T
Old School
This entails an awful lot of work. It might take you all of eight minutes to do both sides of the door. :wink:
Retired Moderator
Depending on the framing---it is ideal to also cut back the drywall at least 8 to 10 inches to remove the part with a layer of drywall mud.
retired union carpenter
if you want a smooth finish? yes. it's best to cut drywall back to center of next stud on both sides. and patch appropriately
Reactions: oh'mike
