can you trace circuits with a clamp meter
eastcoastsparky · Registered Joined Nov 28, 2012 · 189 Posts Discussion Starter · #1 · Dec 2, 2012 Only show this user can you trace circuits with a clamp meter
M micromind · Idiot Emeritus Joined Mar 9, 2008 · 1,910 Posts #2 · Dec 2, 2012 Only show this user Only if they're energized, have current flowing, and no other circuit has the same current. I've used a current clamp to determine which breaker controls a circuit that I want to de-energize without killing anything I want to keep hot. Rob
M McSteve · Mad Scientist Joined Dec 8, 2009 · 952 Posts #3 · Dec 2, 2012 Only show this user There's a trick I learned from someone a while back. You connect a lamp or light socket to the circuit you want to trace, and you use a 100W bulb and one of these flasher inserts to make the bulb flash: http://www.cooperindustries.com/con...es/socket_buttons_1008_472t_125_472b_125.html Your clamp meter will then show that circuit's current draw pulsing at a steady rate, allowing you to identify the correct circuit.
