normal, just tighten screw but do not over-tight
That is the only breaker that should be used in your panelThanks, it's stranded wire and this breaker design seems poor for that. Maybe I'll search online to see if I can find another manufacturer of this breaker. Anyone have experience with Challenger panels and breakers that have a plate to hold the wire like below?
Ridiculousstrip it to breaker spec length, lightly twist the strands, solder the ends (just enough to fill the strands), wipe clean with some alcohol, insert into breaker and tighten to spec.
DO NOT SOLDER! it is against code to do thatstrip it to breaker spec length, lightly twist the strands, solder the ends (just enough to fill the strands), wipe clean with some alcohol, insert into breaker and tighten to spec.
Well, it's not, but still DO NOT solder.DO NOT SOLDER! it is against code to do that
some just dont understand NEC.Well, it's not, but still DO NOT solder.
anyways, soldering is fine as long as you clean any residual flux off. this is much better situation than having bare stranded wires splay apart under the screw force. the soldered strands are now more solid solid copper.
if you have some other reasons for no solder than please share.
