I've been trying to diagnose a problem with one circuit at our new house and I'm stumped. Any advise you can offer is greatly appreciated!
Background: A small hot tub and heater were plugged in on the same circuit and the power to that circuit went out as it would with a blown breaker. The breaker did not look blown but I turned it off and back on anyways. Still no power. Thinking maybe the labels were wrong, I flipped the main and all the breakers just to be sure, still no power to that one circuit. Pulled the breaker out and tested for continuity and it was bad (20amp Square D residential, 200amp service). I replaced the breaker with a new one. As soon as I turned it on, it popped. I turned it off and back on again. It stayed on but there was still no power to the circuit. I pulled the new breaker and tested it for continuity and it was blown. So, I pulled all the outlets and looked for burned wires. Everything looks fine, not even a hint of darkened wires.
The only thing I can think of doing next is trying to figure out if there is continuity between the outlets, although I'm not quite sure how to do that. Does anyone have other ideas? Or know what would cause a circuit to immediately blow a breaker like that? (Nothing except maybe a lamp was plugged in to the circuit when I replaced the breaker.)
