Greetings - I am looking for advice on how many and which recepts/lights to put on what circuit. Attached is the plan I'm using drawn up by a design and build company.
My thoughts: I have plenty of 14-2 wire so will plan to use that for everything except for the bathroom and wetbar as follows: family/entertainment room (7-8 15amp recepts, 8 can lights including the two lights between the stairway and wetbar), office (7-8 15amp recepts, 2 can lights), activity area which is basicall a general hallway (3 15amp recepts, 2 can lights), kid's room (7-8 15amp recepts, 2 can lights), wet bar located just outside of bathroom will have it's own 12-2 recepts on a dedicted circuit, plus 4 can lights). My thoughts are to put all lights (18 or so in total) on one 15amp circuit if possible...ok with two circuits if necessary. Would like any suggestions on how to split up the recepts (not counting the bathroom and wet bar which will be on their own). Will two 15amp circuits be enough for 27 or so total recepts. I will follow the recept every 12 ft rule for living space so there may be a few more than the 27 recepts even.
Assumptions: The 2 bedrooms and bathroom are already done. Bathroom has a dedicated 12-2 20amp gfi circuit. Wetbar will have a dedicated 12-2 20amp circuit. The two BR's recepts are AFCI circuits (15a) and a separate lighting circuit (15a)--this lighting circuit can be piggybacked off of for addt'l lights. Storage room already has a recept circuit. No addt'l recept needed in utility room where furnace and water softener is located.
Would love to hear any suggestions....Thanks!
