1 - 11 of 11 Posts
I need a saw to cut some 1.5" x 1.5" x 1/8" aluminum angle. I thought I was just going to use a grinder but it turns out to be pretty hard to make square cuts with that tool.
I see two DeWalt saws, D28715 and D28710. They seem to be very similar with the "15" having more power and some convenience features. The price difference is negligible, $199 vs $179.
My friend suggested I buy a mitre saw (which I want anyway) and use that to cut the metal instead of buying one of these chop saws. Is that a bad idea? I figured the chop saw might be specially designed so it is not damaged by metal shavings, and cutting a bunch of aluminum or steel with a saw intended for woodworking could tear it up. True?
Thanks
We use regular saws for cutting aluminum tubing and angle all of the time. Just wear safety glasses and gloves because it throws shavings everywhere.
Chop saws would work, but could heat the aluminum to much.
Don't try a regular wood blade on steel. You'll need a chop saw for that.
May I suggest, for the miter saw, to stack and clamp a several pieces to the table or fence. Use an 80 tooth 0 hook carbide blade and protect the motor with a air filter if a ( bunch ) means hundreds of cuts. For your protection you'll need goggles, ear protection and a dust mask wouldn't be a bad idea at all. I wish I had worn a dust mask more earlier in life no matter what I was cutting.
I only need to make a couple dozen cuts.
Would a chop saw without an abrasive blade be the smartest way to cut the aluminum? I'm saving a lot of money by DIYing this project instead of having it built for me, so I can buy a $200 chop saw if it's the right tool for the job. I'll probably use it again someday. :)
Discussion Starter · #9 · (Edited)
I'm going to buy a miter saw anyway. I never used one before, always thought table saw, circular saw, and jig saw were the only saws I needed; but now I have changed my mind.
I just don't want to tear up a new miter saw by getting it full of aluminum shavings. :) This is why I am thinking about getting the chop saw.
· Special User
Abrasive is for steel only. Use carbide for cutting aluminum.
Panty hose over the motor should protect it from shavings.
1 - 11 of 11 Posts
