I have a older house to fix up. And there are some steel pipes, pieces of trees logs, and old Adjustable Steel Building Columns that need to be replaced.
My question is how do I figure out which ones are right for me, I want to make sure that the weight is being held up correctly
other notes -
1 brick column
2 wood tree logs
3 pieces of old metal pipe (2 times thicker then the common adjustable column for a regular house.)
4 adjustable newer jack posts (maybe 30 years old), best guess 18,000 to 11,000 range.
All the columns are rusting or rotting. you can see where some of the rust has dropped through. The house is a 2 two story house 1800's, looks like there is slate put on top of roofing martial. The has had 2 layers slate/shingles for at least 50 years.
Thank you
other notes -
1 brick column
2 wood tree logs
Thank you
