We're having a new roof put on our house. Seems that one of the brick chimneys needs some new flashing. We're in Maine, and up here, lead is the most commonly used flashing material. That is what our roofer intends to use, but... Everything I have read seems to indicate that the standard practice is to step flash the shingles, having the flashing extend up the chimney, and then counterflash from the chimney, with the flashing imbedded into the morter lines, and extending over the base flashing on the roof. Two separate pieces of lead. OK, so what our roofer proposes, and what he sayes has worked for him over the years, is having the lead flashing installed as one piece. The topmost part imbedded into the chimney grout lines, and re mortered, and the bottom part directly step flashed into the shingles. There's Grace Ice and Water Shield around the chimney, and that will come up ehind the flashing. I know nothing at all about roofs, but to me, it seems that if the house and chimney move differently, having the flashing attached as one piece as he proposes... things will eventually weaken, and the flashing may pull from the morter. He sayes the two piece method is "the old way"... He seems to have done a good job on the rest of the roof, though, using better quality materials, working neatly, etc. Any thoughts or suggestions? Thanks!
