Hi
I have a water heater in the basement (natural gas) and a 24acd Englander wood stove on the first floor venting into the same clay lined 8x12 flue. See image I created. When I moved in I cleared out all the ruble and creosote/ash that was blocking the water heater exhaust portion. The previous owner had it running like this!
Issue 1: Aside from the fact that its not to code to run a setup like this (gas plus woodsmoke), I can't get the Woodstove to burn properly. With a good bed of coals and a couple split pieces of seasoned wood inside, the fire will go out with the door closed (with fully open bypass and fully open supply air).
I can get the flue temp up to about 800 degrees with the door open 1/4", but as soon as I close the door, smoke pours down behind the glass and the flue temp sinks down to about 100 degrees. I blew a shop vac up the intake to check for blockages and all seemed clear. I can't even use the catalytic burner because I have to keep the door slightly open. Any ideas of what might be wrong?
Issue 2: I get nasty condensation in the chimney that drips down and leaks around the thimble and down into the basement through the mortar. I know it's bad to have this water heater vent up this chimney but a power vent is too tall for my basement and I think electric water heat is expensive. Can I place one SS liner for each appliance in the same flue with nothing between? What do you guys see as the cheapest/legit option for me? Pellet direct vent in another location and SS liner up chimney for water heater would be my ultimate choice if I had $3000 to spend on this I think.
Thanks as always!
Thanks as always!
