I live in south florida. My air handler is in a small closet (upflow), ducts are in the attic, and many are uninsulated. The ductwork has been hacked over the years, so I'm going for a clean install here. I have a 3 ton AC unit and am assuming 1200cfm. House is about 1800 sqft.
First, the duct plan. I plan on using rigid for the trunks (one 16" right, one 10" left) and mostly flex for the branches to keep costs down. Does anything look ridiculous? I have to follow directly under the ridge of the house because it is a low slope roof (and a flat roof on the bottom) and there is no other way - it has to be set up like that. But do the sizes seem ok? I based it all on some online calculators. (Note: from the plenum, I going to try to have a 16" and 10" takeoff instead of a 16x16x10 wye as in the drawing, if space allows.)
The big problem is the plenum. Right now, there is a 20x20 duct board plenum on top of the AHU in the small closet, and the plenum is maybe 12" tall. Then they put a 14" flex on the top of it that goes up into the attic and over to the trunk. I want to put a taller plenum on, but have a few questions. First, how does the plenum attach to the top of the AHU? And in a small closet (2'x2'), how do you get to the back of the plenum to attach it, etc? I actually have the roof off right now, so I can put in a taller plenum, maybe 2' or 3' total, if I can figure out how to attach/tape it to the top of the AHU in the back of the closet, without moving the AHU which is impossible for me.
Pictures will follow, it won't let me post them yet.
