Hi All,
Our house has a tankless water heater that hangs on the outside of the house (direct vent) I have created an outdoor shop (just a deck and roof -- our climate is fairly mild) in the same outdoor space, and would like to change the vent type from direct vent to using a vent pipe.
The manufacturer (Noritz) has said that the top parts (vent versus direct vent) are not interchangeable. I'd like to "bolt on" a vent pipe/chimney to direct the exhaust up and out of the shop -- a vertical distance of 7 feet.
One way that I have come up with is to simply attach a rectangular vent vertically to the face of the heater. The current exhaust port/vent is a flat oval that is 8.5 inches long and 1.5 inches tall. I'd seal all seams and curve the bottom to direct the flow upwards. I was thinking that a rectangular vent that is around 10 inches wide by at least 2 inches deep.
Does this sound reasonable/do-able? It would be a huge deal to replace the heater, as it heats the house by radiant floor heat. I also don't have a great other option for the location of the shop.
Thanks,
David
Thanks,
David
