1 - 8 of 8 Posts
Hi all,
First of all, let me say thanks as I have frequently came here as a visitor to find answers to my various DIY issues of the day. :thumbsup:
However, today, my question is left unanswered from searching the forum, hence my posting for your help.
I live in a town house that is one of 10 units. Electricity arrives outside in the DWP meters with a 90A main breaker circuit there for my unit. Inside the unit, we have a 12 space / 24 circuit main lug that connects all circuits. The box is 30 years old and has no door, leaving all cables visible.
As I understand that finding a cover for an unknown box is a task not worth spending time on, I decided to change the box for an inexpensive Square D 125A box with approximately similar height and width. (HOM1224L125TC)
Square D also offers similar box with a 100A main breaker for $20 more (HOM1224M100TC) which would give us the convenience of having a main breaker inside the house instead of having to go out in the main DWP box to do so (for example if we need to change a breaker, leave the unit empty for a while, etc).
My question is as follows: if I buy the 100A main breaker box, will I be able to find a 90A main breaker for it so that should the main breaker need to trip, it would trip inside and not outside? (it seems a bit pointless to me to have a 100A breaker on a 90A line :huh:)
Thanks for your help!
A "Handy Husband"
The breaker on the inside panel will be a disconnect only and you can use the 100 amp breaker.
Hi rjniles,
Thanks for the reply.
So if it's just a disconnect, is it just a manual switch then, with no automatic tripping?
Super Moderator
It could, under the right circumstance trip first, but in your case will just be used as a disconnect.
I get it. Thanks.
If I sell the house down the road, it is in compliance with code to have this installation (a 100A breaker behind a 90A one) or will I need to change it back to a main lug box?
(I am in California, if it matters, where NEC2008 is used)
A "Handy Husband"
I get it. Thanks.
It is compliant under any version of NEC. I cannot imagine any local amendment that would superceed but you need a permit/inspection and the AHJ will tell you.
Reactions: pyheme
" Euro " electrician
The only quirk I am not sure about your area but you say Town house with 10 units I rather have this done by electrician so don't be suprised if the inspector say it have to be done by electrician.
Merci,
Marc
1 - 8 of 8 Posts
