1 - 7 of 7 Posts
So, I have drained out the tank and am ready to swap out the lower element. The problem is that some water has gotten inbetween the outer shell of the tank and the tank itself, in and by the area where I access the element part. Is there any major danger of turning the tank back on if there's moisture in this part? Also, can someone tell me how I can accelerate the drying process in this part, if there are any tricks?
The tank is a whirlpool, and is less than 3 years new!
thanks so much for any insights.
Water should be gushing from a faucet where only the hot is turned on, before you turn on the water heater. (Preferably you should also feel vibration from the hot outlet pipe at the water heater proving that water has filled the tank and is running through.)
You can leave the hatch cover off the heater to speed up drying of the insulation between the tank and the outer shell.
1 - 7 of 7 Posts
