Red handle one is the oil return line. You have a check valve B4 the other valve and maybe it is stuck closed. Try tap it from the bottom up continuously while you slowly open the silver valve. Is the tank full or have a lot of oil in it? If it is low maybe there is not enough pressure to lift or swing the check valve open.
