I want to install an electric outlet in my master bath. The ideal thing to do would be to install the outlet where an existing light switch is. The switch controls a light fixture in the closet.
I bought a combo outlet/switch, and removed the switch plate to get a look. Here's what I've got:
One cable running into the box from above. It has one black, one white, and one ground wire. That's it. Three wires.
Can this be adapted to power the outlet as well as the switch? Obviously, some "pigtails", etc would have to be added, as I would need hot wires for both the outlet and the switch. I'm not a good electrician, and am confused as to whether the wiring I've got is sufficient, or if its just a way to break the circuit to the light fixture.
Can the black/white wires be added to to achieve this project?
Thanks for your patience.
