Found a good deal on this
compressor at HF, $39.99 after coupon. The specs list 0.6 cfm at 90 psi and the title says that it's good for inflation, stapling, brad nailing, and air brushing. All of the buying guides that I've seen suggest that around 0.3-0.5 cfm is what you need for a brad nailer. However, all of the brad nailers that I've seen list around 4-5 cfm as the required air supply. I'm pretty sure it will work, but I'm having a hard time reconciling these two specifications. Does anyone know how to compare apples to apples with these?
Also, does anyone have any idea how this compressor would do with a 15 gauge finishing nailer or a framing nailer? The brad nailer would be what I use most, but it'd be nice to know if it would work for something needing more power.
