What is the proper line set sizing for a 4 ton condenser. asbout 40 feet from the acoil/blower
S skifreak506 · Registered Joined May 18, 2011 · 1 Posts Discussion Starter · #1 · May 18, 2011 Only show this user What is the proper line set sizing for a 4 ton condenser. asbout 40 feet from the acoil/blower
Big N8 · Chaos Engineer Joined Oct 28, 2009 · 184 Posts #2 · May 18, 2011 Only show this user Is the condenser above or below the a coil? what size are the fittings coming from the unit?
B beenthere · Administrator Joined Oct 11, 2008 · 42,388 Posts #3 · May 18, 2011 Only show this user The install manual will have that info in it. If you don't have the install manual. Post brand and model number of your condenser. Some brands use a different size then other brands for the same efficiency.
B brandonmcginnis · Registered Joined Feb 14, 2010 · 128 Posts #4 · May 18, 2011 Only show this user Check your manual, but I'll bet it calls for a 3/8" and 7/8".
