If your pipe was properly bedded, backfilled, and compacted you should be OK.
Ayuh,... A few sheets of 3/4" plywood would go along ways,... Cheap Insurance....I go with the person reccomending the planks for weight distribution.
About 12", but at the point where the connection was made it was a 3' x 4' foot hole about 5 feet deep.How wide was the trench?
Do you think that that would hold a fully loaded cement truck? I was thinking 2x10s...Ayuh,... A few sheets of 3/4" plywood would go along ways,... Cheap Insurance....
That's a good idea, but then I also have to have a fairly heavy truck to haul that material in...2x planks will snap like a toothpick to even a half full cement truck. Better find some bridge plank material. 'Here' that would entail finding where the county crew took out an old bridge lately and reclaiming a bunch of old used stuff. A double layer would not be too much,,and it better be on hard level surface,no holes or voids under neath.
It rained a week ago. The deepest section is fairly shaded as well. It's probably still damp down there.recently dug up soft dirt WILL collapse under truck weight if its damp. has it rained in the last two weeks?? Your 2X material MAY work to run a manuel wheel barrow on. If its A LOT of cement get a pumper ,,,but costs are going up quick!!!
I could get a pumper... but I also need to get a lot of gravel in a dump truck. I bet it'll be about as heavy as the cement, but maybe not. I'd hate to have to wheel all that down the driveway, but it might be the only option...If its A LOT of cement get a pumper ,,,but costs are going up quick!!!
Again, check the cost of powered wheelbarrows.. that is what I use. Most all the time additions are in the rear with no access via truck. and if the truck gets stuck you have to pay for the tow and the extra time to get him out.I could get a pumper... but I also need to get a lot of gravel in a dump truck. I bet it'll be about as heavy as the cement, but maybe not. I'd hate to have to wheel all that down the driveway, but it might be the only option...
What do you think about using old railroad ties? I could lay a bunch of them side by side perpendicular to the ditch and then attach them together so that the truck wouldn't move them...I've tried to use 2X materials and several sheets of plywood moving cement with my skid steer bucket and it still will snap these materials. Like you said it is your opinion that counts and it is you that has to hear about the yard smell to your neighbors after you break the sewer line.
