Hello,
I am redoing my fireplace (ave zero clearance fireplace insert). I removed the tile and built a frame around my fireplace. I am installing fake stone (concrete fake design).
I installed 1/2" Duroc cement board onto 2x4 frame using plastic cap nails.
Will this cause me issues down the road with corrosion. They are plastic washers with eletrogalvanized nails.
It is holding no problem and it is a small job, 5 feet wide by 8 feet tall. But I have since read that you need hot dipped galvanized. This is rustic fake stone so the need to be completely smooth is not an issue. My concern is, why this fall apart five or ten years form now from the mortar corroding the nails.
Thank you.
Thank you.
