Installing cement board
I will be replacing tile in a tub enclosure..At the same time I'll rip out the old greenboard and will replace it with cement board all the way up to the existing ceiling (which I'll guess is greenboard). I plan to leave the ceiling as is.
I will of course apply fiberglass tape on the cement board joints including the vertical corners...But since I don't want to spread thinset on the existing finished ceiling, is it absolutely necessary to also tape the horizontal corner where the cement board will meet the existing ceiling? I plan to install tile all the way up to the ceiling so the aforementioned horizontal joint will be covered with tile.
Also how difficult on a scale of 1-10 would it be to install tile using a "hopscotch" pattern with 12" and 6" tiles?
Thanks
Thanks
