I have a ceiling register/grille that is secured by a screw on each end, just screwed into the drywall ceiling. On one end, the drywall has broken, with a chunk between the screw hole and the edge missing.
For now, I removed the grille. What are my options for getting it back in place or a replacement?
Thanks!
Another option would be to bend a piece of 10 to 24 GA metal 90º and screw it to the side of the duct inside and then run your screw into the metal. IF the hole is broken toward the opening for the register, the chipped piece won't show once it's back in place.
· the Musigician
orrrrrr.... glue a piece of thin wood above it with PL adhesive, then screw it back on the next day after the glue has set.
or even sooner if you use 5 minute epoxy.
DM
