I have been working on removing popcorn ceiling from my house and repainting the ceilings. I started in my main upstairs hallway and I have completely removed the popcorn texture. Once that was removed, all that was left was the drywall and joint (basically looked like I had just drywalled and taped the joints). I sanded the surface to make sure it was smooth and even, and filled any gouges and scrape marks with joint compound and then sanded again.
At that point, I was thinking it was time for primer and topcoat. I applied the primer, but after drying, it looked like the paint was cracking and peeling. The cracking and peeling happened in patches all over the ceiling, but primarily (>90%) happened at the edges of the ceiling. I did a bit of research online, and read that the best way to take care of it was to scrape and sand the cracked areas and fill them with joint compound, then sand again. And that's where I am starting to have serious problems. I started scraping and the paint is coming off in HUGE strips (some are as big as 2 sq ft) in some areas and in others the paper on the drywall is tearing.
So I am in need of lots of help. First, if my wife doesn't kill me, how can I fix this? Where did I go wrong? Did I miss a step somewhere? If there is any info I can give to help figure this out, let me know.
tl, dr: I REALLY SCREWED UP MY CEILING PAINT JOB (read above for specifics)! HELP!!!
