I am in the process of leveing and furring the basement ceiling to be drywalled. However was not sure what to do about the ends of the furring strips.
I am using 2x material for this, mainly because it gave me the depth that I needed to keep screws at least 1 1/2" away from anything you could accidently screw into.
My main issue right now is at the ends there is no joist to screw into vertically. Right now it is butting up against the top plate on the end wall of the room. This is because the room divider walls where placed directly below the joists so you get a complete vertical wall from floor to the 1st floor's decking (apparently for fire stopping going by the house plans) so no ridge to screw into vertically
Does this need to be somehow attached at the end? everything I've seen online just leaves it hanging, even with Hat channels and stuch the ends just hang there.
The joists are 16" O.C. right now and I am screwing the furring strips up with 3" screws
This probably will support 5/8" drywall for the ceiling.
