I have 2 ceiling fans (motor only, no light) that appear to be hooked up in series to one switch/controller. I replaced both fans and when I powered to test, the switch seems to now be connected to lights that are on other switches in 3 gang box. Fan switch was inconsistent and did not turn on at first, then turned on fans, then when tried switch again the fans and can lights (on other switches) came on. Is there a way for me to troubleshoot this problem? Didnt touch switch, just replaced fans. Fan at end of series has 12-2, 3-wire so black, white, ground only, the fan in middle has the 12-2 from other fan, and also a 12-3, but the red wire wasn't stripped and dont think was connected to anything. I have 2 other switches in gang box that control can lights in room, but should operate independently. Not real savvy at electrical, but figured was just replacing fans. Thanks,
