Have a dimmer I am replacing for a ceiling fan light. The ceiling fan is controlled by a single swtich (on/off). The light is an old leviton dimmer that only has the toggle (bottom off, top on, dim in middle, no slide bar Single black to connected to the yellow wirenut,and red going out to fan light). The dimmer only has black and red, no ground. going to replace with a new lutron dimmer that has the brass and copper for the two wires, but the lutron also has a green ground.
? Does the green matter that much if the fan is grounded via the on/off for the fan motor? or a the motor and the light two completely different entities in the fan housing? Just curious.
