I need some help. I am installing a ceiling fan to replace a light fixture. When I disconnected the light fixture, it had white wire and black wire. The electrical box has two white wires and one bare wire for ground. When power is on, my volt meter shows 120 volts on one white wire but none on the other. Is the one white wire with no voltage considered a neutral? Whats more confusing is I could have sworn the light fixture I took down was connected to the neutral... Is that possible? The wiring instructions say to connect one wire from the fan to the neutral and two other wires to the hot. I just want to make sure I am understanding this correctly before I proceed.
Thanks!
Thanks!
