1 - 6 of 6 Posts
I am putting in a new ceiling fan and am running into an issue. From the ceiling 2 wires are down, one is from the switch the other leads to a a junction box. When hooking the fan to just the junction box wire, I get it to work but when I hook up to the switch as attached, it blows a switch when I flip the switch.
Can anybody tell me where I am going wrong? I had an older fan hooked up just fine.
In the box there are two sets of wires both have black, white and ground. The Ceiling fan has the standard Black, blue, white, green.
it is a switch loop setup,
do you know which wire is which?
which one goes to the switch? which one is power incoming?
assuming you do....
incoming hot/black connects to the white wire to the switch
incoming neutral/white connect to the fan white
incoming ground connects to the fan ground and switch wire ground
black/hot from the switch connect to both black and blue on the fan
Super Moderator
What do you want the switch to control? fan? light? or fan and light?
The above directions will control the fan and the light.
If you only want the light to be controlled then connect only the blue to the black from the switch and connect the black from the fan to the black hot and switch white. The fan will be controlled by the pull chains.
Discussion Starter · #6 ·
joed: The switch is going really just going to turn power onto the whole fan light included, then the different settings can be turned on or off by the pull chain.
anyacolo: Thank you for explaining that. I will work on it tonight and see if that setup works. Thank you
1 - 6 of 6 Posts
