Aprox 1 month ago i installed a ceiling fan/light combo where there was an old light fixture in my bedroom. I purchased the fan from walmart and it worked fine untill today. I was laying in bed , the light on the fan was not on. the fan was running on low and for some reason it popped and a spark fell out of the fan burning out before it landed on the floor. basicly it looked and sounded like a blown light bulb but with the added spark..
anyway, the Fan continued to spin and i have no idea why it happened. I turned the light switch off that powered the fan, checked the box and it had not tripped the breaker. I then turned the power off to that room, took the fan down and inspected.. The wiring was just as i had installed it ( black and blue, to black in ceiling , white to white in ceiling, green to green which was also grounded directly to the fans plate screw.. ) There were no burnt or melted wires.. so then i took the light fixture apart and that also had no signs of wire malfunctions.. i could not get the actual fan motor apart but it appeared fine.. i even smelled it trying to detect that burnt out smell but couldnt..
So now i am extremely confused. the wires in my celing are capped off and im afraid to install another fan without knowing what the problem is.. like i said the light wasnt on, after the sparks the fan continued to spin, and there is no sign of burnt wires or anything wired wrong.. what should i do?
