1 - 9 of 9 Posts
I'm trying to put up a new ceiling fan but the house has old wiring(just black and white.) Power comes in at the fan and goes to the switch(end of run.) Can I still use the ceiling fan buy capping off the ground??
BUILDER / REMODELING CONT
Is the existing wiring BX. I would connect it to the box and the ground on the bracket from the fan.
what is around the wire to protect it before it connects to the box. is it a metal casing or is it a soft waxy fabric ?.
Banned
It's the old fabric-sheathed cable.
Yes. You can use the fan. Ideally you would rewire the house, but since that is unlikely, you can put the fan up, being extra careful to make sure you have good connections that aren't likely to come loose and energize the metal of the fan.
Super Moderator
I agree. Not much of a hazard here. How many people can reach a fan on the ceiling?
You do need to make sure that the box is rated for a fan, and that it is attached between or to joists propertly, or it (the fan) may pull the whole thing down!
1 - 9 of 9 Posts
