1 - 10 of 10 Posts
I have a Hunter ceiling fan (remote only controls) that you can control the fan with the remote, but you can't turn off the lights so you need to unscrew the light bulbs to turn off the lights.
Any suiggestions on how to fix?
Thanks
Electrical Contractor
The DIP switches affect both the fan and light functions. IF the fan works, but the lights don't then the dimmer module in the remote receiver is probably shot. :huh: Changing the DIP switches won't fix this. :whistling2:
Did you hook up the blue wire from the light kit to the blue wire on the receiver? That sure sounds like your problem to me. There is a wiring diagram on the receiver. One wire for the light and one wire for the fan. Check the connections in the ceiling box. The dip switch settings have nothing to do with your issue. If the fan comes on with the remote so should the light. If it's connected correctly take it back and get a new one.
1 - 10 of 10 Posts
