I replaced a light fixture with a ceiling fan with light fixture. The issue is the wall switch will no longer control the light/fan. I install them so both the light and fan is controlled by the wall switch meaning I can flip the switch to turn the light/fan on or off at once. My issue is the room where I installed it has 2 wall switches one on either side of the room that both control the same fixture, just so no matter what side of the room you enter you can turn on the light. The problem I have is the wall switch no longer controls the fan meaning if I have the chain pulled and the light on and flip the wall switch to the off position the light stays on, it doesn't matter which switch I use it never turns the light off. Here are the wires that I have. I have black, white and bare wire coming from the ceiling. Looking at the wall switches, there is a black white and red wires on there. Anyone have any idea how to wire this so the wall switches will work again? Thank You
