Hello, and thanks for whatever help I get in advance.
I recently moved a ceiling fan from one room to another. When I installed the fan in the new room and it worked just fine, but the switch setup forced me to put the light kit and the fan on the same switch. To remedy the problem, I installed this light switch/fan control combination:
http://www.lowes.com/pd_70804-539-SFSQ-LFH-WH_0__?productId=3189469&Ntt=lutron+fan+light&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dlutron%2Bfan%2Blight&facetInfo=
Unfortunatly, before I installed it, I did not notice that it was a solid state control.
Guess that's what I get for changing my mind at the last second about which switch to get. Once I installed it, my fan got all messed up. Now, I have to figure out how to fix it. I removed the solid state control and have it back to the normal switch.
What the fan is doing is odd. Sometimes when I turn it on it works fine (especially when I put it back together after messing with the wires). It will work for a short amount of time, but then the fan will all of a sudden stop and turn the other way for a little while. Then, it will continue running the correct way, but at a super slow speed. I also noticed that the switch to reverse the direction of the fan doesn't do anything.
The first thing that I thought to do was to replace the capacitor in the fan. This did not help. So now I have to figure out what to do next. I think that the problem is with the wireing and not the motor because it works fine some of the time, and especially when I mess with the wiring for a second.
What would you check/try to fix next?
