I have two fans that no longer operate at their proper speeds. One fan only spins at low speed while the other spins at low and medium. The used to be controled by remote, but the receiving unit malfunctioned, so I took them out. I replaced the speed switch on the low only fan but the problem remained, so I put the original switch back in. Then I replaced the 4-wire speed capacitor (which showed no sign of damage) and the fan still only spins in low. The lights still dim properly so no problen with that capacitor. I'm not an electrician so I don't know if there's something I'm doing wrong or it's something else that I'm unaware of. I could use some good advice here as I would prefer not to replace both fans. :confused1:
