I had a cedar column installed to replace a rotted pine one. The installer used cedar to make the post and originally attached everything with staples and glue (Titebond III).
I had the "base" redone because they installed the grain going vertically and I wanted the end grain to be exposed so I can paint it and not have it wick water. A different guy did the redo and he used caulk and nails to attach the base to the vertical column. This was done 3 weeks ago.
I just went to look at the column today and I noticed all 4 sides of the cedar "base" have a split/crack in the middle (near the middle nails).
My questions is: Why is the wood splitting? Is it because nails were used? Or is their something else I may be missing. I want to redo this cedar base but I don't want it to split or crack again (at least not this much).
