Hello,
I want to run 8 CCTV cameras and 8 motion LED lights from one 12V 20A power supply. My cameras are rated as 500ma and the lights are 850ma. I will have eight wires coming off the power supply. Each wire will be running one camera and one light. I am using a Y splitter to split the power to the camera and LED light.
So how many amps would be going through my Y splitter? They are rated for 2 amps. I assume the devices only draw the minimum they need, so 1.35 (500ma + 850ma) total amps are traveling through my splitter to the devices even though my power supply is 20 amps. Is that correct? Am I safe to use Y splitters rated for only 2 amps with a 20 amp power supply as long as the devices connected directly to the Y splitter are under 2 amps total?
Thanks
Thanks
