caulking the windows
1123 Views 6 Replies 3 Participants Last post by  anon125
where the glass pane meets the plastic frame there is a gap and it looks like the "caulking?" has shrunk.
do we just clean the muck out and use bathroom/ kitchen caulking to fill it up? it has been wet - condensation-so there is a wee bit of mold.
thanks all
1 - 7 of 7 Posts
Post up a picture. That is usually part of the glazing bead and designed, to some extent, to allow moisture that bypasses that area to drain out.
You would normally use a clear silicone there.
the window frame is white- just looks odd in the pic.
shows where the caulking seems to have shrunk.
does it usually do that in a 13 year old house?
thanks
It's a little hard to tell , but I think your first pic indicates that you're talking about the setting material . Either foam tape or adhesive that the glass seats on . Unless you are getting noticeable air leakage , it really isn't hurting anything. AND , if you try to aggressively dig it out , you can break the glass in a hurry !
You probably should frequently clean the entire window & sash with a bleach solution to kill the mold .
Reactions: 2
thanks. so I should not caulk it? I hoped to fill it up so that water did not sit in it and cause mold.
It would probably be better to leave as is . Unless you can get the mold & moisture OUT , you would probably be sealing it IN .
However
, if applying a small bead of silicone could , say , keep you out of divorce court , caulking would seem prudent !
:biggrin2:
thanks very much
1 - 7 of 7 Posts
