I am installing a cast iron Kohler tub and had some questions....
I have 1/2 inch plywood underlayment on top of 5/8 tongue and groove subfloor..planning on 1/4 inch hardibacker butting up against tub...the tub is now sitting on the underlayment...according to Kohler's instructions...all I need to do is shim for level both ways...and that should be it...or am I missing somthing...
my questions are :I have read about using a ledger board ... Kohler says it is not recommended.. should I use one anyway ???...and should my tub be sitting on the subfloor only to ensure the feet are carrying the load or should I now shim all 4 feet to raise the tub up a bit??? I am concerned that the apron might be carrying some of the load the way it is sitting now....
thanks for your help
Last year we did a hotel rehad with about 1000 Kohler cast iron bath tubs. Since we didnt have access to the back wall or sides we used a ledger board to carry and help us shim the tub. We would wedged a pry bar between the floor and the underside of the tub. With my forearm I would push down on the pry barwich would lift the tub and with my hand I would shim the legs with large metal washers. Sometimes because of the drain we would have to lift the tub about 3/4" again we would shim the four legs and apron.
www.No-Curb.com
We installed this Kohler Cast Iron tub yesterday to dry fit the plumbing.
What a heavy tub.
My plumber and I tried doing it ourselves but it was to heavy. We sat it down in the wrong spot and crushed the trim base a little. Lucky for me it gets hid by the tub - just barely!
With three of us we managed just fine.
Now to patch the floor and set the last tile.
JW
just finished up kohler villager cast iron install in my house. used a strait 2x4 screwed securely to wall as ledger, took a few trys of sliding tub in and out until it was perfect. first time installing cast iron tub and my plumber said he only uses the ledger. i recently put a steel 1 in a customers house , feels cheap. cast iron was alot of work , but feels solid.
