I am in the process of gutting my bathroom in which I will be installing a new subfloor, Ditra and 12" floor tiles. When I pulled the toilet up I noticed the flange was rusted out. Upon further inspection it looks like the flange is welded to the sewer line.
1) Should I remove the old flange? What is the easiest way to remove it?
2) Or do I keep the flange in place and install one of those PVC Twist-N-Set Closet Flanges?
If you suggest option 1, what would I use to connect the new pvc flange to the old cast iron sewer line?
If you suggest option 2, how would I cut the old flange down so the new Twist and set isn't too high.
Thanks for your time.
