I need to change the vent line for my kitchen sink. No real problem, but I'm wondering how to handle the hub coming out of the slab. The vent is 2" cast iron. The house was built in 1965. It looks like the 2" cast iron is stuck into the hub and hot lead poured around it.
Can this hub accommodate ABS pipe via some sort of conversion fitting, or will I need to have a small length of cast iron fitted and then convert to ABS?
Images attached. Thanks for your input.
Well, even rotating and re-uploading the images don't give me proper orientation. Should be portrait. I guess cell phone images for uploading need to be shot in landscape.
