The plumbing code for my city says specifically: "Hubless cast-iron pipe shall not be permitted for inside leaders." I've googled inside leaders but I can't figure out what it is. The first hit on google is something called a rain leader, which may be inside or outside.
Some context on this, I'm trying to replace a rusting away piece of cast iron with a hubless cast iron which I'll connect with the right couplings. Also there is a vent pipe to the right of a double vented trap that vents out, and I'm thinking about replacing that. Is that a leader? A pic can be found in this thread.
Another thing I'm wondering is Home Depot sells cast iron 4" DWV pipe but it says "for underground use" but then goes on to say "for use in a dwv system". So does that mean I can use it above ground?
How should I hang the pipe? Cast iron is so heavy and all the hangers I saw at Home Depot seem so dainty. They sell strapping but it's a very thin gauge. You can actually see I already used it as a stop gap in the pic. Is there a certain thickness required?
