I've been debating over this for a year now. I'm going to have to cut part of this anyhow to install a 3" Wye for second-floor front load washer, so I'm wondering if I should just add supports to the cast iron stack, and cut it just below where it enters wall in photo one. This would leave about 10' of cast iron from cut to where it exits roof.
I would then cut it (I'm thinking) just above where PVC pipe is with rag hanging out of it (last photo,) right after it curves horizontal, or below PVC pipe. And then replace everything in between with 4" PVC. This would allow me to reconfigure smaller bathroom (it's back-to-back with main bathroom) layout if needed. I was going to replace all cast iron drain pipes in smaller bathroom with PVC when I can get to it.
My question is could I use the same pipe layout as currently there, just with PVC fittings? Or would I have to use a 45 degree double wye fitting for toilets? Doing so will drop the drainpipe even lower than configuration I now have.
What I'm afraid of is that if I cut that cast iron to install that 4x4x3 wye, even with good strapping, that it will not be rigid and the heavy cast iron will be able to shift.
I will take advice given. I am tired of losing sleep over this and it's holding up progress.
Thanks!
-Thomas
Thanks!
-Thomas
