If you want to remove the lead- use a 1/4" drill bit. Drill several holes into the lead around the circumference. Pry out whats left with a screw driver. Now you should be able to wriggle the pipe/fitting out of the oakum.What's the easiest way to remove lead from 3" drain pipe without damaging female connection? Without burning rig. My bottle is empty.
