The house was built in 92 and looks like no maintenance to the windows was ever done. I believe the windows are Marvin and are aluminum clad on the exterior. The location is central Minnesota, where ice forming on the bottom edge of the glass can do a job on wood. Also, some of the windows have damage on the hidden inside of the bottom member, caused by trapped humidity over the years. I have attached some pictures.
I am looking at a long project of progressively tackling all windows in the house. I was thinking about making some blank covers with hardboard plus foam board and some weather stripping, with a couple cross members held with butterfly nuts and bolts, so I can remove a sash and plug the opening while I repair it. I have a lots of questions...
1) Are the sahses very heavy? I am concerned that they may be too much for me and my wife (70's), in which case I would have to look for help to remove/install in batches instead of piecemeal.
2) What should I use to clean the wood, overall inside and in the hidden dark moldy areas at the bottom.
3) I was thinking to carefully sand the bottom quarter round profile by the glass, holding a wide drywall blade to protect the glass. I wonder if I should apply Minwax Wood Hardener, before or after sanding or not at all.
4) Do somehow similar work on the lower damaged hidden areas of some sashes. I suspect windows on the north side might need some Minwax High Performance Wood Filler, which hopefully will be hidden, and not become a cosmetic issue.
5) Use some Minwax stain to touch up the sanded areas.
6) Refinish the whole sash and window frame with... ? Should I use something like Minwax Helsman Spar Polyurethane? Is there a way to find if it will be compatible with the old finish? How many coats?
7) I wonder if I should break out and remove the bottom frame member that covers the mechanism. Last year I had to replace a couple of mechanisms and I found there was a lot of crud built in. I also noticed that the area under the cross member, was not ever finished, I do not know if because of process/savings or because they intended for it to breath. Should I seal/finish that area? The bottom members are nailed in. I was wondering if I should place them back with long #8 Phillips brass screws.
8) The pictures show some scratches on the bottom of the frames caused by the cats. Is there a way to deal with them? I mean the scratches, not the cats :smile:. At some point I thought about getting some properly milled 1/8" pine or even oak strips to recover a couple of the worst ones.
9) Should I systematically replace all the weather stripping? I wonder if Mervin still sells it for the old windows.
I will really appreciate any comments and suggestions...
