I have a Carrier 58UHV060-12 Natural Gas furnace. The ICM blower module failed and was replaced. This in not a PSC ( Permanent-split-capacitor) motor. My first question is, if you apply power (120 VAC) to the 5 pin connector terminals and leave the control plug ( communications, 16 pin connector) REMOVED from the motor what should the motor do? Run at full speed or not run at all. Everywhere I have researched I have not found anywhere that it should run until you hook up common 24 VAC and G ( fan), but a local HVAC contractor tells me it should run. This answer will determine where I proceed from here.
