Hi, I have a Carrier HVAC 48HJE014 unit for my business. We are based in Westchester County, NY. They are natural gas units. I recently replaced the heat exchanger (actually did it on two units) and it worked out very well. The one unit is acting a little weird, here are the symptoms:
**when heat is called for, the blower motor comes on, the ignitor clicks/sparks but it takes until the third time for it to ignite the furnace. It seems as if the gas does not start flowing right away or until that third try. It is a natural gas system.
**when it's lit, everything then seems to work normal.
**It did have two error codes, one for the flame sensor and one for the limit switch, which were both replaced, then the error codes went away--it did not change the "delayed light" problem however.
**if the unit is up and running all day, at some point there will be a real bad smell of gas inside, which I can only figure is coming from this same unit, because if I shut it down and air the place out, it goes away and we don't have any problems if that particular unit is turned off completely and the other unit is on.
I am guessing that it is either a problem with the gas valve and it not operating and/or opening up properly or whatever control unit tells it to open up.
I'm clearly not an hvac repair guy but have done enough fiddling and watching and repairing on my own to know a lot about the units, but not 100%
If anyone has some useful guidance that would be fantastic!!
