my furnace will run until the room is to the thermostat set temp. It then goes to the blower only. The led flashes 1 short 1 long then 3 short, it is 8 years old
hi on the panel some place on the furnace there should be a label explaining the codes ,, look see what code it is and let us know which saftey its going off on,,model number to will help
I believe a code 13 means that a limit or roll out switch has be activated for more than 3 minutes.
Either the furnace has been overheating/ the flame has been rolling out the front of the heat exchanger/ the limit or rollout switch is faulty. This is code that may be indicating a serious monoxide condition.
Do you have a/c? (dirty coil?) Are all the heating and return vents open or uncovered? Do you have dirty air filters in the heating outlets?
A electrical meter will tell you if either the main limit or the roll out switches have tripped.
A temp rise test will tell you if the furnace is actualy overheating.
1 - 9 of 9 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
