This is an interesting one. My Carrier gas furnace will run a complete heat cycle (thermostat set to 70, furnace will heat to 71, and then stop as expected). Right after it stops, the red LED on the circut board will turn off, making it appear that there is no power going to the circuit board anymore.
Some time later, when the heat should come on again, suprisingly, it does (and the LED is then on). Again, a complete heat cycle will occur. And, again, when that cycle ends, the LED will turn off.
Every couple days, when the heat should come on again, it does not. I typically have to turn the thermostat off and on, turn the power switch (the one that looks like a light switch that is next to the furnace) off and on, and have to press in the furnace door switch several times. Some combination of those things will eventually cycle the furnace on again; I have not figured out an exact sequence that causes it to come on again.
I know that the LED light is supposed to stay on solid when the furnace is idle, so I can't understand how the LED can turn off after a heat cycle (indicating no power to the board), and then the thermostat can call for another heat cycle. I think the LED stays off until the thermostat causes that next heat cycle to start, but can't be 100% certain as I have not stared at the LED waiting to see if it somehow comes back on prior to the next heat cycle.
It's as if power is going to the board in some manner since the thermostat is causing a new heat cycle to occur. Could a bad furnace door switch cause this intermittent oddness? I know that the circuit board would not get power if the door switch was broken. The door switch is obviously not broken though since the heat will come on after the LED goes off, but maybe somehow the switch is having intermittent problems??
Any ideas are appreciated.
