Hi,
I'm not an hvac but I'm a good diyer. I normally stay away from the hvac stuff but I had to take the chance on this project because It is a packaged unit (no freon to remove\add) and it is replacement to an older model.
I bought the AC unit (carrier 48ss-042100331) from a lady who had an electrician carefully remove the unit. Unfortunately, one red wire was disconnected from the circuit board for one reason or another.
After setting up the new unit by running the ductowrk, I ran test the AC and it was cold and nice. I'm able to perform all functions except getting the AC to shut off automatically when the set temperature has been reached. The thermostat and its wiring are fine, but when I looked the unit and I noticed red led light ON the control board. It is not flushing!!
I'm thinking that the red loose wire my have something to do with this problem. There is an 'L1' available connection I was going to reseat it but not sure if it that's the right place. I checked at the manual but couldn't make sense of the wiring diagram located in this pdf at page 21.
Please let me know if I should connect the red wire to L1 within the circuit board.. I don't want to chance it nor hire a contractor for 200.00 to do a 5 sec work.. Thanks.
