1 - 7 of 7 Posts
Normally, with carriage bolts I use only ONE washer behind the nut because of the square area just under the head of the bolt requires you to use a washer much larger than the bolt diameter.
Now I'm wondering which is correct. Do I need to put a washer under the head of the carriage bolt as well. I will be using 8 inch long X 1/2" inch bolts through 6"x6" posts. Thanks for the information.
This is why I don't use carriage bolts on decks, you get much more bearing surface with regular hex bolts and washers on both sides. With carriage bolts I find the head is too small to prevent the head from cutting into the wood, esp fresh damp PT.
Carriage bolts are designed to pull the square head into the wood . You only use a washer on the nut end
ChuckF- I'm using the carriage bolts on some very heavy framing of a Post & Beam barn. Carriage bolts are needed because the finish siding of the building will be over the bolt heads so I need a relatively flat head surface. I can't get a flat surface with a hex bolt. But I do agree with you that hex bolts with a washer under the head will prevent the bolt from sinking.
Civil Engineer
You can get a flat surface with hex bolts by countersinking the bolt head flush with the face of the post. Looks good, and it is much easier to tighten or remove a hex bolt than a carriage bolt after a few years, since you can get a wrench on both sides of the hex bolt. When I countersink, I use a forstner bit to make the countersink holes, large enough to fit a wrench or socket in place.
1 - 7 of 7 Posts
